Thank you and more
Hi All
Thanks all for the great advice.
Thinking of going for omni since I can't see the mast even from the chimney as according to Googlemaps I am about 70-80 feet too low. I am also further than I thought at about 2.3 miles.
The elevation line is from my house to the mast (looks to be about 80-100 feet when you see it). My added straight line is one showing roughly the altitude you'd have to be at to see the mast; I hope this makes sense.
Its a shame since I own the woods above me and if I could run a 100m cable up the hill and then attach the antenna to the top of a tree it would probably work like a dream! I am assuming that antenna cable lengths are limited right?
Anyway, here is my router info:
1 PLMN: 20820
2 Service status: Valid service
3 RSCP (dBm): -97
4 ECIO (dB): -5
5 RSSI (dBm): -99
6 Roaming: No
Finally, thinking of this antenna if directional is not going to work (before purchase I would appreciate confirmation that people think it won't) and also that it is worthwhile to purchase an omni. Seems to say that I need 2 of them for 4g but I only get 3g for now.
http://www.solwise.co.uk/3g-antenna-omni-0069.htm
First step will be to put the router into the loft (there is a window opening) and cat cable down to the floor levels.
Hi All
1 PLMN: 20820
3 RSCP (dBm): -97
4 ECIO (dB): -5
5 RSSI (dBm): -99
6 Roaming: No
