DTMark
0
OK have answered some of my own questions - got a BT Powerlink triple kit and have wifi all over the house, and now have ethernet over to studio, getting 50Mbps! Watched iplayer tonight for the first time without any buffering.
Should I use the two supplied mini antennas? Should I get an outdoor antenna?
The setup you have, is basically the same as we have. Just don't go streaming anything very hi-def in Netflix (e.g. a 10Meg stream). The peril of having this level of speed is that the player will take advantage of it and pick the highest quality stream, and it goes through data very fast
The B593 has internal antennae but I think some of them came with a pair of clip on antennae to supplement this. Mine did not. It's plugged into a roof antenna so I can't comment on whether the ones that come in the box are any use.
I'd give it a month or so and see how it goes before spending more as you're getting very good results, see if they are sustained. I'd be surprised if you get very much more from it, but then I've been surprised before
