daleski
Hi Guys,
Looking for some advice, my Virginmedia connection is down more than it's up so took the plunge and got a 3 branded Huawei B535 on contract, currently I am getting anywhere between 30 and 55mbps indoors with no external attena's
According to HuaCtrl I am always connected to the same mast no matter what which has 15mhz of bandwidth (is that the right word?)
So the question is what is the maximum throughput I can likely get if there looks to be no carrier aggregation on 15Mhz? i.e would buying antennas actually be worth it?
Stats for reference.
CELL_ID 2597120
RSRQ -6.0dB
RSRP -92dBm
RSSI -69dBm
SINR 12dB
Wireless transmit power PPusch:-1dBm PPucch:-15dBm PSrs:0dBm PPrach:2dBm
Uplink mod/demod of MCS mcsUpCarrier1:29
Downlink mod/demod of MCS mcsDownCarrier1Code0:0 mcsDownCarrier1Code1:0
PLMN 23420
CELL_ID 2597120
RSRQ -6.0dB
RSRP -92dBm
RSSI -69dBm
SINR 12dB
PLMN 23420
