5G Boardband Outdoor Hub + Eero NAT questions
GazCBG
I am thinking about getting 3 5G Outside Hub + 1 Eero and got 2 questions about the NAT if anyone knows
I was to be able to use it on my Xbox sometimes, but am worried about the NAT it uses.
Is it CGNAT or regular/standard NAT?
If it is CGNAT, can I get out of it by contacting 3 support or getting a static IP from 3?
Regards,
Gaz
Three broadband doesn't use CGNAT if you use the '3Internet' APN, but if you set the router to any other then you will be behind CGNAT. Gaming will work fine.
Even without CGNAT it's dynamic IP though. No option for static IP with Three. You'd have to go elsewhere if that was super important to you.
EDIT: Looks like someone beat me to it!
Thanks for the replies :)
The reason I asked about CGNAT, as on the Xbox it give a Strict NAT and cause issues.
I could always try it and send it back within the cancellation period, if it has got CGNAT.
If the router allows it, try opening the ports for it and UPnP
You should be fine if you use the '3internet' APN GazCBG, this is what I get on my Xbox using it on a Zyxel NR5103E. :)
