Now that are you online LeeH, could you confirm if Zen can request thr target SNRM to be fixed?
Yes, we are able to set a target SNR now via BT. It came into action a few months back.
I have to disagree with AAISP reply though. Yes the 10 day rule applies (offically), however, calling BT you can get it manually adjusted if as an ISP we mess up![]()
But, can you also get it fixed so DLM will never change it? That is what I would really like.
Aquiss, any response to the above question?
I still don't have any speed increase. Is it normal to get no increase? Stats:
Line state: Connected
Connection time: 0 days, 00:29:06
Downstream: 7.69 Mbps
Upstream: 1.09 Mbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 6.1 dB / 5.9 dB
Line attenuation (Down/Up): 39.2 dB / 21.8 dB
Output power (Down/Up): 20.3 dBm / 12.7 dBm
FEC Events (Down/Up): 4998 / 93
CRC Events (Down/Up): 4 / 32
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 6 / 10
Error Seconds (Local/Remote): 4 / 0
