Darsuke
I'm using a Three sim in a Huawei 535 router and trying to locate which mast it's connecting to.
The router displays the cellid. I've used various websites and android apps to see this mast. They all provide the cellid but none of them match the router connection.
Any tips to get something more accurate?
I'm also trying to understand CA on the mast. I can manually connect to Band 20 with slow speeds or Band 3 with faster speeds. The cellid changes for each of those so obviously different masts I presume. The router always states a 4g connection. If I put an EE sim in there the connection shows 4g+
In simple terms does 4g+ mean I'm using CA?
