Liono
Super Pro Member
How have you found the XPOL-24 so far? I’m in a similar position being rural, debating going down the route of 2 P-60’s and 2 P-62 for 4x4 MIMO or picking up an XPOL-24. Would rather avoid the headache of mounting the Iskra’s and dealing with the wiife!
Only tested in the loft so far, am away on hols so will mount in September. P-62's appear to give marginally slightly better upload speeds and 5G signal strength, but a bit subjective in the loft and cabling differences with the xpol-24 might be at play.
The P-62's use Accordia Vector WL240 Cable.
I've used X-400 10m cable and also H155PE which is better than LMR240 but not as good as LMR400, but much more flexible.
The LMR400 is apparently 0.3dB loss per meter at 3.5GHz, but man is the cable ridiculously stiff. So much so that having four attached to the XPOL-24 makes it rather difficult to orientate and must put stress on connectors perhaps.
When I'm back will mount outside.
