Battery usage in different bands
jf812
Hi All,
I am having issues with battery consumption on my ageing device , and am wondering if restricting bands will help with this. I was thinking that B20 only would be best as the coverage is greatest, and the device wouldn't need to work so hard. Also, would it vary depending on network? I have a Lyca and a Three SIM ATM
Many Thanks
Using dual SIM will be the biggest user of battery. I suggest turning the SIM that isn't your main off whilst not using it and having it forward all the calls to your first SIM.
