Best 2.4 Outdoor Wifi to send signal 300m away?
Sounds like a dud if there are no lights, maybe the power supply? I'll let the MicroTik experts take over to help more!
Okay have you found the reset button
yep does nothing. noticed it looks like there's 2 lights on the poe adapter, neither is lit up despite both being plugged in. will see if i've got another eu-uk plug adapter to see if that's it (it came with one).
Tplink power supplies are a good substitute
Anyone got any recommendations of another brand? I've just had to send the Microtik back for a refund, completely dead device. Not buying another one of those.
Tplink cpe210. I have one, seems to work well, but never tested at long distance.
Btw, mikrotik are very good, shame you were sent a dud.
TP-LINK EAP110-Outdoor. We’ve bought a couple of them for our new house. Takes less than 5 minutes to install and sends a signal 250-300m away. Probably the best device I’ve bought recently, lol. If you face difficulties installing and using it, try to look for some info on https://multitechverse.com/. Tbh, I bought the wifi according to the recommendation. Anyway, keep us updated, man. If you have problems with that wifi model and find nothing on the Internet, let me know, and I’ll try to help you.
Not sure how tech savvy.. but you did have ethernet cables plugged in the right way round? To the router is unpowered. To the radio is powered?
I used TP-Link CPE210 Pharos Outdoor 2.4Ghz for my application but that was PTP mode - 1 at either end. Can still connect to the wifi at the house end with a phone or tablet. Not sure on max distance, but should be pretty far outsdoors.
When choosing an outdoor WiFi access point, it's important to consider factors such as range, signal strength, weatherproofing, and ease of installation. It's also important to choose an access point that is compatible with your existing WiFi network and any devices that will be connecting to it.
  1. Ubiquiti NanoStation M2 - This is a high-performance outdoor WiFi access point that supports 2.4GHz and has a range of up to 15 km. It features a compact design and is easy to install, making it a popular choice for outdoor WiFi applications.
  2. TP-Link CPE210 - This is an affordable outdoor WiFi access point that supports 2.4GHz and has a range of up to 5 km. It features a built-in 9dBi directional antenna and is weatherproof, making it suitable for outdoor use.
  3. EnGenius ENS202EXT - This is a high-power outdoor WiFi access point that supports 2.4GHz and has a range of up to 800 meters. It features a built-in 5dBi omni-directional antenna and is weatherproof, making it suitable for outdoor use in harsh environments.
  4. Mikrotik GrooveA 52HPn - This is a powerful outdoor WiFi access point that supports 2.4GHz and has a range of up to 2 km. It features a built-in 6dBi omni-directional antenna and is weatherproof, making it suitable for outdoor use in harsh environments.
Strange that you don't recommend Ruckus?
