Broadband Help Needed
Alicefan
Hello,I`m looking for some help with a broadband issue. I am with Virginmedia and have 2 x V6 boxes one in the living room and another in a separate garden room. In the living room where the router is I`m getting 110 mbps but in the garden room I am only getting 20mbps, I want to be able to stream football etc with an Amazon firestick, the garden room has a separate electrical supply to the main house, I`ve tried the virgin boosters but they don`t work, I`ve also tried the BT Whole Home WI FI but that doesn`t work either. there is a brick wall and a 4 foot gap between the main house and garden room, would another router do the trick ( Virgin won`t provide another router as it`s 1 per household). I hope this makes some sense ,any help would be gratefully received. Thank You.
What quality you streaming? 20 meg should be enough.
Best way would be a cable to the TV from the router
Hi, its not a broadband issue by the sounds of it. It will probably be the internal network (your LAN) that is causing the problem/bottle neck. Using a physical cable like CAT6 cable (known as Ethernet cable) is always better than using Wi-Fi when it comes to connecting to the internet or a network (and more secure), if you cant use CAT cable then a good access point might help. I had customer last week with a similar issue he got a good access point & connected it to his router, problem solved.
Virgin Media £24.00
Shell Energy UK ISP Logo
Shell Energy £26.99
109Mbps
Plusnet £27.99
Zen Internet UK ISP Logo
Zen Internet £28.00 - 35.00
Gigaclear £15.00
YouFibre UK ISP Logo
YouFibre £19.99
BeFibre UK ISP Logo
BeFibre £21.00
Gift: £25 Love2Shop Card
  1. FTTP (5472)
  2. BT (3505)
  3. Politics (2524)
  4. Openreach (2291)
  5. Business (2251)
  6. Building Digital UK (2234)
  7. FTTC (2041)
  8. Mobile Broadband (1961)
  9. Statistics (1778)
  10. 4G (1654)
  11. Virgin Media (1608)
  12. Ofcom Regulation (1451)
  13. Fibre Optic (1392)
  14. Wireless Internet (1386)
  15. FTTH (1381)
