spile
I have BT FTTP (Smarthub 2) and a copper landline that is being moved to Digital Voice.
I also have a VOIP line that I pay Voipfone £2 a month for. I use a Gigaset N300 to connect the VOIP and landline.
The obvious way forward is to connect the N300 directly to the Digital Voice port of the Smarthub 2 when I am switched over - As it is a PSTN port, I assume this will work?
So effectively N300 connects to SMARTHUB2 via LAN (VOIPFONE line 2) and also PSTN/DIGITAL VOICE (BT provided line 2)
Are there alternative options that I should consider?
I presume that I am not going to save anything by moving the landline number to Voiphone as I would still have to pay line rental (residential) and outgoing call charges would be higher than BT?
