BT hubs
timeless
Staff member
Volunteer Mod
just wanted to find out something, lve got some issues connecting to a wireless access point, l have the wep key and it does supposedly connect.. but l keep on getting a limited connectivity error...
the person who owns it has no idea how to set it up and he has gone away, l was just wondering if this limited connectivity issue could be down to mac address filtering or if there was an issue with some bt modems.
I have no problems with mine. ME connected via ethernet. XP connected via USB and laptop Vista via WiFi.
all lm getting is limited to no connectivity... l know the key is right, however the netword connection details are stating that lm not getting the default gateway IP, which is why lm wondering if the access point has mac address filtering.. or dhcp isnt turned on or something..
it would be great if someone had some possible solutions to the issue, l know if its MAC related then ld have to add my mac to the allow list however if there is another possibility it would be great to find out, about the best thing l can note is that this is a BTBusiness Hub if that helps ppl any
seems l had the key wrong, the digits at the end were messed up... windows didnt actually tell me that it was wrong which was annoying!
from the settings they seem to be missing upnp havent seen mac filtering yet either its a BT2700HGV, and from the looks of it the control panel information lve seen on google this ones been updated.. has something called BTopenzone on it which l think is pointless since its easy to get around.
