No recommendations, but if you have good RSRP I recommend to let it be.hi
since many of you here have this router NR5103E (which btw works very well with internal antennas) does anyone have a recommendation for a 4x4 mimo external antenna that does not break my wallet?
or could i just use 2x2 on the 5g connectors to boost 5g?
thanks
You tell meNo recommendations, but if you have good RSRP I recommend to let it be.
Looks good to me, I get decent performance with an RSRP of -90
