bufferbloat prevention help and info
cyberfruits
hi
We are on community wifi broadband.
i am not sure what i have installed as it was provided by my wifi broadband provider but it could an airgateway and a poe or just poe and I was hoping somebody could look at the picture and advice. Also, I got bufferbloat and apparently if I get a router that allows SQM adjustments this can help, can somebody recommend a replacement for my "router setup" which allows sqm?
Router would usually connect to the LAN side.
Might be worth seeing where that white cable goes first.
Matt
The PoE injector acts as wifi for us, but we need an ethernet connection, so the white cable goes into a switch, but we were having some problems lately with latency and bufferbloat.So looking for a solution for that like Smart Queue Management.
Latency is an inherent service ‘defect’ that can’t really be improved upon. Unfortunately wireless tends to have higher latency than terrestrial connections. Also jitter will be higher which makes life difficult for ‘real time’ apps including voice. It is what it is really.
SQM works to tackle bufflerbloat which is inherently an end device defect, basically the router fails to keep pace servicing the packets running though it and the packets then have to queue, delaying their passage.
It could be that the underlying/inherent latency and jitter on the service is actually what is causing an issue rather than router bufferbloat.
