JM98
Dear All,
I am looking getting broadband to my home via a 4G signal which I can only get some distance form the house (approx 400 MTRS)
Finding components is fairly easy but I have not fixed my choices. However for the purpose of figuring out how to power this by solar I would have the following:
https://mikrotik.com/product/lhgg_lte6_kit (uses less that 8 Watts) PoE powered
https://mikrotik.com/product/wireless_wire_cube (max 9Watts).PoE powered
The Solar controller (could be) https://eu.store.ui.com/collections/operator-sunmax/products/sunmax-solarpoint as it provides 4 PoE outputs.(uses 2Watts)
(the down side of this one is that it uses 24Volts so would require 2 - 12 Volt batteries in series but the plus is that I don't need a 12 to 24 or more converter or two separate PoE injectors.
Does anyone have any idea how I can figure out what Panels and batteries I would need or where I could find this information?
(I want to make sure the system stays up and running 24/7 even during a long spell of Devon rain..
Many thanks!
Jaap
Many thanks!
Jaap
