Can't surf when using Azureus (bit torrent)
KDS
when I use azureus I can't surf any website or makes the websites very slow I limited the upload 50kB/s still no luck
any one got any idea :)
Are you using the 'safepeer' plugin - you know the ip blocker? This may cause probs when surfing round sites.
Azureus does not have a very good speed limiting mechanism, and previous poster is correct that upload can stop from browsing as well, if you want to limit speed you should try something like netlimiter (www.netlimiter.com). be warned though this software uses LSP (Layered Socket Protocol) and can conflict with your firewall software e-g ZoneAlarm....
or try Bitlord, I have no problems and have left it running a 7.8gig download while I surfed with no problems.
I think it's my D-link dsl 604T router when it's doing port fw it's just stopping the surfing :( need a new router any one recommend a good one :)
gone give Bitlord a try :)
Hi KDS,
I have the same router and dont have any problems with it have you changed the MRU at all?
I'm a bit late on this one but for the record...
i use ABC and have had no problems, sure thing slow down a bit if theres alot goin on but i just thought that normal. Bit of a 256u/l bottle neck as it were.
ABC
No I didn't change the MRU I dont have a lot of port open.
but I get this error when I try to delete on of my rule from the Router "ERROR: cannot change a rule in use" I dont think it's in use tho :S
I dont have this rule as active :S
