Did you apply for any trial beta tests etc, or just upgrade your plan?Full works for iPhone.
I'm not aware of being on a trial. Today I upgraded my plan.Did you apply for any trial beta tests etc, or just upgrade your plan?
I’ve had better ping on NSA!What plan are you on?
Btw lol at SA, it's not a bad ping but hardly great either, originally 5G (nsa) was touted as having sub 10ms pings, then they mugged that off and said SA would be the saviour. Well it turns out it's all bollocks I guess
Good to see you hereI'm not aware of being on a trial. Today I upgraded my plan.
It was minutes. Did a speedtest after getting off the phone and saw it said SA, which surprised me!Good to see you here
You’d know if you were on the trial, you have to sign up to it, Centrecode would be periodically bothering you for feedback but EE would covering your line rental.
You’re the first person we’ve seen with SA since the plans launched in the wild. How long before
You changed your tariff before you started to pick it up?
At a guess, on my side I see Capabilities NSA+SA, and while the 5G indicator is showing either:
- No 5G section in FTM
- A 5G section without Band, Bandwidth and Cell Id showing
At a guess this means the 5G indicator on my phone is fake?
Example
Talking of phone calls - does it drop back to 4G or NSA in FTM when you make a call? If not then VoNR is probably live tooIt was minutes. Did a speedtest after getting off the phone and saw it said SA, which surprised me!
Do we have VoNR in the UK yet?Talking of phone calls - does it drop back to 4G or NSA in FTM when you make a call? If not then VoNR is probably live too
No, but it seems very likely that EE will deploy it first. They did some trials quite a while back for it: https://www.ispreview.co.uk/index.php/2023/09/ee-makes-first-uk-mobile-call-via-5g-network-vonr.htmlDo we have VoNR in the UK yet?
It’s also available on the new All rounder plans. Have you recently updated your plan?My EE app shows a 5G Standalone addon in My Addons, but I’m not on a full works plan
Think VoNR does appear to be active on EE SADo we have VoNR in the UK yet?
I'll need to pop down to the Shuttle Bus depot sometime and see what happens with O2's SA.Think VoNR does appear to be active on EE SA
Just tried it outside there as the SA signal wasn't reaching inside which was unusual, just switches to 4G, but I forgot to switch VoLTE off, it's off now so will try it again when I manage to get SA again, without walking to the other end of the town.I'll need to pop down to the Shuttle Bus depot sometime and see what happens with O2's SA.![]()
you'll need it on, so that it is registered with the IMS - used for VoNR too - and doesn't try fall back to 3G/2GJust tried it outside there as the SA signal wasn't reaching inside which was unusual, just switches to 4G, but I forgot to switch VoLTE off, it's off now so will try it again when I manage to get SA again, without walking to the other end of the town.
Sorry I know this is in the wrong thread.![]()
Ah that's true Gavin, I forgot about the 2G/3G malarkey, well it's just 4G.you'll need it on, so that it is registered with the IMS - used for VoNR too - and doesn't try fall back to 3G/2G
