I seem to be unable to combine my 2.5ghx and 5,6ghz names on my Huawei router. I change the name to the same and it says that both networks cannot have the same name. I'm sure it works okay on other routers? Can anyone help?
Thanks, it is quite frustrating. I'm sure on my previous Huawei CPE pro 2 it wasn't a problem, just checked a box saying give the 2 networks the same name!View attachment 6217
Not sure if this is just a Huawei 'feature' but all my previous Huawei routers were the same, as an OCD sufferer this made me very uneasy indeedy.
As you say, the CPE Pro 2 is no different, mine is banished to the cupboard and my SSID's are now OCD friendly thanks to the soap dispensers.
Hope someone can help you out with a way to get round this though.
I just gave up and named them 2.4 GHz and 5.0 GHz.(Was not happy)
Yes I found it very frustrating too sja0001.Thanks, it is quite frustrating. I'm sure on my previous Huawei CPE pro 2 it wasn't a problem, just checked a box saying give the 2 networks the same name!
Yeah I had that problem with all my Eufy smartplugs Bigyinuk.Eufy vacuum cleaner won't connect to a SSID that is both 2.4 and 5ghz. I always split mine for the reasons outlined above.
