D-Link Releases Firmware to Fix Mass Router Security Vulnerability
Mark.J
Administrator
Staff member
ISPreview Team
Own a D-Link router (e.g. DIR-300, DIR-600, DIR-615, DIR-645, DIR-815, DIR-845L, DIR-865L, DSL-320B and DSL-321B)? If so then it's strongly advised that you update to the latest firmware after an easy to exploit security flaw was discovered that could give others access to your router.
http://www.dlink.com/uk/en/support/security
http://www.devttys0.com/2013/10/reverse-engineering-a-d-link-backdoor/
In the meantime D-Link are advising owners to ignore unsolicited e-mails that relate to security vulnerabilities and prompt you to action, make sure your wireless network is secure and to also disable remote access to your router. A little common sense about network security hopefully means that most people should already be doing this.
