olisones
First time poster so hello! This is a bit long winded, but I hope someone might have some ideas...
I have been running a 4G set up with Three for a while, firstly with a B315 with paddles and more recently a B525s-23a in bridge mode as I'm also using an Eero mesh set up.
I decided to get an outdoor antenna as our speeds had dropped quite a lot (from around 25mbps to 8mbps). This was partly due to Three working in the area (which apparently has now stopped without much improvement) I purchased the Poynting 4G-XPOL-A0001 as have placed it around 10ft up on a first floor terrace (so around 25ft all in).
For some reason, I can't seem to get decent SINR numbers, despite the RSRQ/RSRP being okay. Here's a snapshot:
SINR: 3db
RSRQ: -12db
RSRP: -81dBm
I'm now getting around 5 - 8Mbps down and 20Mbps up.
These were taken with LTE H-Monitor.
The odd thing is, when I swap out the XPOL with some 9dBi paddles, I get much better SINR:
SINR: 15db
RSRQ: -10db
RSRP: -85dBm
With the paddles I get about 20Mbps down and 1Mbps up.
I'm currently on Bands 3 + 20. I've taken the router of bridge mode incase this might affect things. The cell tower according to Cell Mapper is about 200 meters away, however this is the opposite side to our property.
I'm flummoxed as to how the smaller paddles get a better connection. I wonder if anyone can help shed some light on this? Do The better upload speeds suggest cell congestion?
Many thanks!
SINR: 3db
RSRQ: -12db
RSRP: -81dBm
SINR: 15db
RSRQ: -10db
RSRP: -85dBm
Many thanks!
