is there any particular reason why my uploads speeds is near double my download speeds ?
Yes other masts were giving much higher readings, and speed was much the same, this is as good as I could getThose connection stats look spot on.
Could just be a lot of users on that mast taking a slice of available bandwidth.
Have you tried locking onto any other mast in your area?
When I have had that issue I have had to play around with the antenna, moving around a bit and doing speed tests sorts it out, sometimes you can get reflections so a direct aim is not always the best.
