Distance vs Speed question
I am finally get enabled mid January and according to the link I can only get 512k because of my distance from the exchange, however it cant be that bad as I have ISDN already and guess the distance to be no more than a mile.
If I order a 1meg connection will this be turned down or will they test the line for speed to see if I can support it?
I thought I read somewhere that technology has evolved where a 512k can now make it to a 1meg line?
Hers are the limits, old first, and as you can see the 1MB has a new limit of 60db from the original 41mb.
512k: 60dB None
1Mbit: 41dB 60dB
2Mbit 41dB 41dB
BT are also increasing the range for 1Mb/sec premium services from 4km to approximately 6km - making 1Mb/sec ADSL available to 96 per cent of homes and businesses connected to a broadband exchange.
I think you may wish to enquire with BT once your exchange is enabled,
Hope this helps.
Keith
If you order 1mb and it fails the test for 1mb they do not give you the option of 512k instead. To get the 512K you have to place a new order, what I did was order 512K, I now have the otion to upgrade for a fee (£11 from memory) but have not found the need yet. If the upgrade fials at least you still have 512K.
