Does TP-Link WD-9000 VDSL/ADSL router work with FTTP??
CopyJ
A supplier said it should as port 1 of 4 is a WAN/LAN.
Tried configuration using username and password, and tried using auto-config from Dynamic IP
Still cannot get FTTP up and running. ONT has all lights on (apart from LOS)
ISP says OR engineer did not do radius log so on diagnostics they cannot see any PPP sessions and there is not data.
OR engineer has said - its the equipment..... I told him we have tried 3 routers!!
Totally lost.
Please help. Shall I try and different router (manufacturer ie 4th router)
Give us a clue. What ISP?
You could connect directly into the ONT and set up a new PPPoE connection directly from laptop / computer. That will prove your creds are correct
