Draytek 2925 to load balance two 4g connections to get around FUP?
I have a Draytek 2925 and its 2 wan connections go to a Three mast and an EE mast. To get over the useless surfing on Three at peak times the Draytek points all surfing on ports 80 and 443 to EE, all other traffic uses both wans. Works well and data gets shared pretty well equally but there are settings that will set limits if needed on the Draytek called WAN budget, it allows monthly limits and you can set the mobile contract date for the proper monthly rollover.
Just a quick question regarding the 2925, Do you have to put your two 4g routers into bridge mode?
how do you handle WIfi?
Have had both 4G routers in Bridge mode and not in Bridge mode and both work for surfing and downloads. If you game online then you will need bridge mode on the Three router and it set to use the right APN for a unique IP address, plus the Draytek set to direct all gaming traffic to the Three WAN. Alternatively you could keep the Three out of bridge and ethernet directly to it from the game consul missing out the Draytek.
My 4G routers are in a workshop and their WIFI is not strong enough in the house so the Draytek is used but as the house is U shaped with 2ft thick stone walls most rooms have bridged Routers with wifi all wired back to the Draytek.
