E5783B - Adding external antenna connections
Rousie
A little side-quest while i find the right gear for my Caravan :)
I'd like to add some SMA's to this little E5783B which I've got lying around so i can mount an external antenna outside of the Caravan for some testing.
I've got some Mini PCI UFL SMA connectors floating around and I'm more than confident and happy to get soldering, but even after searching, i cannot find where i would solder the soon-to-be stripped wiring to!
While disassembling, I accidentally pulled off the spring connector pad under the black cap (first image) but i can sort this out later - not sure if this is WIFI or LTE?
Could anyone help advise where i'd need to solder and if it matters which way the wiring would go?
