EE APN for wireguard
Hyuukai
Don't know if anyone here is using a VPN to connect to there hosted services? i am trying with limited knowledge it seems that EE uses cgnat but also uses a dual stack? not sure if that means i can use ipv6 to configure wireguard or not? also deep in a forum somewhere i saw an EE apn eezone? does anyone know about this apn at all?
Wireguard simply works over default EE settings. Why complicate things?
It doesnt as EE using CG nat?
Wait, wg client or server? Can't really host a server because of cgnat as you say. There is no apn that will give you a public IP on EE. Get a cheap vps and host your server there.
Server, but they use 464xlat so can i use ipv6?
Maybe, but seems flimsy to me, imho. My VoIP does not work on EE for example, they seem to be blocking ample amounts of udp ports, I am using a vps for wg.
Try ipv6 and see how it goes, do let us know.
