Tiger009
Hi Members,
Thank you for reading my post. Any help is appreciated.
I currently have a Huawei B535-232 with an O2 sim card in (in contract for another 18 months or so).
I would like to maximise the download/upload speeds I am getting. Currently very slow. Previously I was using id mobile(three) and the speed was better but as now in contract want to stay with O2.
I had purchased a Poynting Xpol 001 about 18 months ago but not fitted it yet, have done some testing. (omnidirectional antenna)
I have found my local phone masts using cellmapper and tested the speed when near the masts (100 mbps+)
The cell mast that the router connects too is 652m away. (ENB ID:507236)
Although there is one closer it always connects to the one 652m away/
I have tried to place my router in different locations in the house and these are the readings I am getting.
Would a directional antenna improve the reading significantly. The mast is quite far away
Any advise on how to improve speed and where to place the router and weather to purchase a directional antenna is appreciated
Front bedroom
reading one:
RSRQ-7.0dB
RSRP-98dBm
RSSI-73dBm
SINR23dB
reading 2:
RSRQ-11.0dB
RSRP-87dBm
RSSI-59dBm
SINR8dB
Office
RSRQ-7.0dB
RSRP-92dBm
RSSI-69dBm
SINR2dB
Middle
RSRQ-9.0dB
RSRP-91dBm
RSSI-65dBm
SINR6dB
Front room downstairs
Internal
RSRQ-8.0dB
RSRP-102dBm
RSSI-73dBm
SINR8dB
Following readings are with external antenna
Right (90 degrees)
RSRQ-11.0dB
RSRP-95dBm
RSSI-67dBm
SINR13dB
Right (45 degrees)
RSRQ-9.0dB
RSRP-95dBm
RSSI-69dBm
SINR8dB
RSRQ-10.0dB straight
RSRP-97dBm
RSSI-71dBm
SINR5dB
Left (45 degrees)
RSRQ-10.0dB
RSRP-96dBm
RSSI-69dBm
SINR2dB
Left (90 degrees)
RSRQ-9.0dB
RSRP-93dBm
RSSI-67dBm
SINR13dB
Front bedroom
reading one:
RSRQ-7.0dB
RSRP-98dBm
RSSI-73dBm
SINR23dB
reading 2:
RSRQ-11.0dB
RSRP-87dBm
RSSI-59dBm
SINR8dB
Office
RSRQ-7.0dB
RSRP-92dBm
RSSI-69dBm
SINR2dB
Middle
RSRQ-9.0dB
RSRP-91dBm
RSSI-65dBm
SINR6dB
Internal
RSRQ-8.0dB
RSRP-102dBm
RSSI-73dBm
SINR8dB
Right (90 degrees)
RSRQ-11.0dB
RSRP-95dBm
RSSI-67dBm
SINR13dB
Right (45 degrees)
RSRQ-9.0dB
RSRP-95dBm
RSSI-69dBm
SINR8dB
RSRP-97dBm
RSSI-71dBm
SINR5dB
Left (45 degrees)
RSRQ-10.0dB
RSRP-96dBm
RSSI-69dBm
SINR2dB
Left (90 degrees)
RSRQ-9.0dB
RSRP-93dBm
RSSI-67dBm
SINR13dB
