Fault for customers on 50mbps, 75mbps, 150mbps, 200mbps, 300mbps, 400mbps packages
Barnet
It was going so well, but on Saturday morning (01/10/22) the Internet stopped working for me.
Down Detector suggested it was a common problem with 100+ fault reports.
Shortly after I submitted my fault report (using another connection) Community Fibre had an "initial discovery" report on the service status page.
It looks to me like a problem in the CG NAT system as the higher speed packages (that have a dedicated public IP address) were not included in the fault report.
Can confirm that there was no outage on the 1Gbps package. Suggestion that it’s related to CGNAT connections seems accurate.
That being said, I love how quickly they are to react and fix these things!
Thanks Matt.
Comparing some tracerts during and after the fault I can tell where the data “got lost” and my best guess is that it was a routing fault.
The limited monitoring I have suggested that the fault occurred at 1am - 3am so it wasn’t quite as fast a fix as you might think.
I’m also mildly suspicious of the quality of network monitoring as the first mention of the fault on the service status was shortly after I raised a ticket although this could be a coincidence.
But it was fixed reasonably promptly and I’m very pleased with the service generally.
