Find which mast it's connecting to on 5G broadband router Huawei Cpe pro
zakir1988
I need some help if anyone can possibly help me out.
Im using Cpe pro
I went into system details to find out which mast it's connecting to what I can find is just cell Id:143689,
with other info but no lac, mcc and mnc with them info I can't search for the mast it's connecting to in my area.
I'm getting full bars on Three 5G
How do I find them.
https://www.ltehmonitor.com/en/ should work well on the CPE Pro and should provide a lot more information.
However, you should be able to find the cell on cellmapper even without the utility. Go to cellmapper.net, open the map and find your location, select "3 UK" as your provider and then open one of the masts that show up on the map in your area. One of the Cell Identifiers listed in the left-hand pane will match your cell ID.
I found it on cell mapper when I press 5 NR nothing shows up only for 4G LTE but I found the location where the 5G signal is coming from using the 4G LTE search
I'm not sure if the cell ID reported by the CPE, or you, is the 4G or the 5g cell.
Assuming it's the 4G one then that is eNB 561, which you should be able to search for on the cell mapper site.
However, with 5G currently being non-standalone (NSA) the serving mast for your 5G connection could be a different physical site to the 4G connection (the anchor) so while it's likely to be the same mast as the 4G, it's not guaranteed to be.
Edit: eNB 562 looks to be at Rosegate House, 3 Hereford Road, Old Ford, Bow
The cell ID is the same as the one showing up on cell mapper showing LTE A cpe pro is receiving 5G signal full bars green light. It has to be a 5G mast
