aix
I've been having issues with my FTTC line. For about two years it was syncing at 20 Mbps down and was stable. Recently it went to DLM-imposed 10 Mbps. I spoke to the ISP (Zen) who reset the DLM.
The line is now syncing at around 20Mbps but is not very stable.
You lot are very knowledgeable, so I thought I'd ask here in case anyone is able spot any issues with the below or suggest troubleshooting strategies. Thanks!!!
P.S. I am about a kilometre away from the cabinet (wire length).
Code:
cisco-c897va-k9# show controllers vdsl 0
Controller VDSL 0 is UP
Daemon Status: Up
XTU-R (DS) XTU-C (US)
Chip Vendor ID: 'BDCM' 'BDCM'
Chip Vendor Specific: 0x0000 0xC190
Chip Vendor Country: 0xB500 0xB500
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x4602 0x0000
Modem Vendor Country: 0xB500 0x0000
Serial Number Near: (redacted) C897VA-K 15.4(3)M4
Serial Number Far: Q10K1002039_22
Modem Version Near: 15.4(3)M4
Modem Version Far: 0xc190
Modem Status: TC Sync (Showtime!)
DSL Config Mode: AUTO
Trained Mode: G.993.2 (VDSL2) Profile 17a
TC Mode: PTM
Selftest Result: 0x00
DELT configuration: disabled
DELT state: not running
Full inits: 15
Failed full inits: 0
Short inits: 0
Failed short inits: 7
Firmware Source File Name
VDSL default flash:vdsl.bin
Modem FW Version: 140729_1209-4.02L.03.A2pv6C039m.d24h
Modem PHY Version: A2pv6C039m.d24h
Trellis: ON ON
SRA: enabled enabled
SRA count: 14 13
Bit swap: enabled enabled
Bit swap count: 70 673
Line Attenuation: 0.0 dB 0.0 dB
Signal Attenuation(dB): 23.6 59.8 N/A 9.2 47.1 0.0 N/A
Noise Margin(dB): 5.8 6.7 N/A 6.0 5.9 N/A N/A
Total FECC: 821296050 2839
Total ES: 8577 208
Total SES: 3220 0
Total LOSS: 14 0
Total UAS: 485 485
Total LPRS: 0 0
Total LOFS: 20 0
Total LOLS: 0 0
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 23163 0 6959
SRA Previous Speed: 0 24045 0 7000
Reed-Solomon EC: 1501 371595499 0 76
CRC Errors: 211745 211745 223 223
Header Errors: 0 0 0 0
Interleave (ms): 0.00 0.00 0.00 0.00
Actual INP: 2.01 44.00 0.00 0.00
Training Log : Stopped
Training Log Filename : flash:vdsllog.bin
Code:
cisco-c897va-k9#sh run | sec controller
controller VDSL 0
operating mode vdsl2
modem ukfeature
modem customUKAnnexM
modem customUKAnnexA
sra
