FTTP advertised speeds - performance?
BFG
I'm just kicking off a Community project to bring FTTP to our village. There's quite a bit of interest, and I'm wondering what other people's experiences are so I can pass them on.
Questions from the village...
Q. With FTTC broadband I've never got close to advertised / contracted speeds. How does FTTP improve on that? Will we get what we pay for?
Q. What happens to my BT phone? Does that swap over to the new fibre line or...?
Q. Is this going to be the 330Mbps or the gigabit? (How can I tell)
From my knowledge:
Q1 - FTTC speeds/performance is based on the degrade from the remaining copper line. Therefore, FTTP should generally give you a stable speed of what you pay for (there could technically still be a bottleneck with the node the FTTP lines are connected to if there is a heavy bandwidth user but unlikely since its unlikely anybody would be using a continuous 1Gb transfer for a while)
Q2 - Currently I believe OR leave the old copper lines for phones but eventually they will need to be either removed (for the better, no sales calls) or transitioned to IP phone via routing device.
Q3 - You should be able to select a different package for each property but the max you can currently get (BT wholesale wise) I believe is ~900Mbps DL and ~120Mbps UP. They will give you a smaller speed guarantee though so if it drops during peak times, you can't really complain.
Adding to those from Samuel.
Q2. This depends on your choice of ISP too. At present BT can also offer a Digital Voice (VoIP) alternative, as can Sky, which means your existing phone handset needs to be plugged into the router instead of a wall socket. Otherwise your number should still be retained. Ofcom are also due to introduce an improved process for number portability, which should make it easier to swap your phone number to all sorts of different VoIP platforms or networks.
Q3. Generally you'll have a choice of speeds since FTTP is just a line, which supports many package options from 40Mbps and all the way up to 1Gbps. Only in some older areas that were deployed on Openreach using ECI kit will the fastest package be limited to 330Mbps. Generally anything being deployed now should support top speeds of up to 1Gbps. At the end of the day, it's a matter of consumer choice as to what speed you pick.
" Only in some older areas that were deployed on Openreach using ECI kit will the fastest package be limited to 330Mbps. Generally anything being deployed now should support top speeds of up to 1Gbps "
Wish it was the case, brand new cable installs in Feb this year, stuck on 330Mbps, all the older stuff, literally stones throw away, same exchange can get 900Mbps. No idea why we cant, tried asking and gave up, went cityfibre as well to get my 900Mbps fix.
Thanks guys, very useful.
Re Q2. I think the concern is practical rather than technical. I currently use VOIP myself with a ported number, so I'm comfortable with how it works myself.
But people's baseline expectation is to replace FTTC with FTTP and retain their landline with no addition cost or inconvenience.
But the reality seems to be they will either need to keep both lines, or, go through the inconvenience & cost of engaging a new service.
Most people have their landline and broadband through BT.
