GreenLantern22
Exactly. As long as there is a conduit laid out for your ISP installer and a string to be able to pull he cable they will be more than happy to use it. It simplifies their installation and they don’t need to deal with the issues they don’t want to deal. Also consider that you can use this conduit for multiple ISPs (if you are lucky to have multiple ISPs provide FTTP at your address). So make sure you have a couple of strings to pull another fibre cable if needed.Ah thanks very much, that's very helpful. I'm not sure I can do that myself, but would you suggest I find a subcontractor that can run a conduit for me? Sorry to ask a silly question...
