uknowiama
Super Pro Member
Girlfriend's place in rural location can now finally order Gigaclear. Up until now we have been using ADSL over a copper phone line. Backed up with 4G connection. Internet connection uses both with a load balancer has been working quite well for 2 year. After a bit of advice.
Do we get the fibre installed same was as telephone line. It comes into the property via a telegraph pole. Its a bungalow, so isn't that high. Has been cut a couple of times by a tractor with a front arm up (flat 8 I think).
Do we make the effort to dig a trench out to the road and lay a duct / pipe - put a rope in (to be able to pull any further ducts / fibre through) and use that to bring the fibre into the property? We have a digger for such things.
What would people do?
Also ... looking at just 200Mbps, been offered an introductory offer on 500Mbps for not a little more - but concerned about price once out of contract? Is it same as other ISPs, if you tie in for another 18 or 24 months you get better prices? Say £17 for 200Mbps, out of contract is £41. Then if renew will you get something like £17 (same as new customers) or something like £22 - it's cheaper but not as good as brand new customers.
Guess - as altnet (I think that's right) - its Gigaclear on Gigaclears fibre - no options of other ISPs?
What's happening with copper lines? Are they going or did they have a reprieve? Landline currently gets quite a bit of use. Or look at a deskphone that uses 4G and a cheap SIM? VOIP is also an option? But perhaps if Internet goes off we don't want the phone off as well?
Thanks in advance
Thanks in advance
