rruwalton
ISP Rep
My central heating / hot water programmer timer cracked up yesterday as a relay went pair-shaped, so I went to B & Q and purchased a new one.
My brother- an electrician swapped the wires like for like but, although we have checked and re-checked the wiring the thing wont work properly. He has no real experience of c/heating systems.
At the moment the hot water heats up but the thermostat for the central heating has no effect. You seem to need both the hot water and central heating on to get the pump working. I am sure we have misplaced a wire. If you alter the valve to manual which is in-line with the tank, the central heating works. Its a bit of a mystery and to sort it we need to work out the wiring colour codes.
So I'm after some help with the wiring please. The wires must be colour coded i.e. blue = neutral / red = live. However, I also have yellow, orange and brown wires.
The following units connect into the timer with there being 6 connection terminals on the timer, 2 being a live feed and neutral, so only 4 other terminals. Hot water / Central Heating.
I have a valve, a spur supplying voltage, thermostat wires from the water tank, and a pump.
If someone could give me some guidance I would be much obliged.
Thank you in anticipation
