help with internet explorer plz
hi, i've got windows 98 and all was fine till now, all of a sudden i can connect to the net but internet explorer wont load any pages, i'm on broadband so no probs with my connection and my opera works fine. i've not changed any settings or anything. it gives the "unable to connect" to whatever web page i choose "check network settings messagage" any ideas plz
do you have a proxy installed?
Have you re-booted your PC and ADSL modem/router ?? this often clears any problems.
How do you know if you are connected if nothing is loading?? does email work OK?? its just my ADSL connection went down for most of Tuesday and Wednesday, it said it was connecting but it was being cut off withing a fraction of a second.
Proxy settings
With Internet explorer open ,from the menu at the top of the screen
E.G. File Edit View etc select Tools >then > Internet Options >then from the tabs at the top of the Box that appears select Connections.
from here it depends on your method of connection
ADSL Router
If you are connecting to your broadband via a router then you will need to select LAN Settings found near to the bottom of the Connections area, in the LAN settings area, you are looking for a tick in the box under the heading Proxy Server and next to Use a Proxy server, if this is ticked and something is set in the box labelled ADDRESS and PORT, remove the tick and click OK and try Internet explorer again..
ADSL MODEM
If you are connecting via an ADSL/Broadband modem then you will need to select your connection from the box with the heading Dial-up and virtual private network settings, Once your connection has been highlighted select the Settings button found to the right ,here you will be looking for a tick in the box under the heading Proxy server ,remove the tick , click ok and try Internet explorer again.
You might also click on File and check that WORK OFFLINE from the drop down menu doesn't have a tick by it.
Having written all this doesn't the Opera browser use Internet Explorers settings ?
We hope this is of help regards Naims.co.uk
I have opera 8 and it doesnt use ie settings but it does have connection settings and can block sights from opening
just go to tools
preferances
advanced
click proxy servers
remove any check mark that is checked
Your dns settings inn windows could have changed if you have a firewall
go to start go to network connections
right click on the icon
go to properties go to general
left click internet protocol [tcp/ip]
click properties just below
put a mark in obtain ip address automaticly
click alt configuration
put a mark in
automatic private ip address
this will set your windows os to work without a proxy
not had chance to try it yet but also does the same on ordinary dail up modem too
You don't happen to be using ZoneAlarm do you? Since the last update I've been having an occasional problem with ZA changing the Program Control setting for Internet Explorer to block all access all by itself - maybe it thinks IE is too unsafe :laugh:
