YuGi
i use the QNAP 301w router which has two 10gb ports, one for wan and other for lan, the rest is 1gbps ports.ah yeah I see, could a different router fix this you think? (any recommendations?) tbh I just have the hub setup, with the wifi off, 10gb ports going into the switches etc
i just ordered a new router "
XIAOMI 10 Gigabit Router"
which have 1 - 10gbps sfp port and 1 10gb wan port, then the rest of the ports are 2.5gbps.
this router is from aliexpress, still waiting for it after 7 days but it should be on the way now.
