Huawei 5G CPE Pro Missing Settings
josb99
I am in the U.K. and have just received my Huawei 5G CPE Pro router which I purchased from an independent retailer (not a carrier). The router is fully unlocked and is performing extremely well in terms of speeds. However, whilst changing devices over to the network from my previous router, both the Xbox One X and PS4 warned me that the NAT type was strict and Universal Plug and Play (UPnP) was disabled. This is something I would usually be able to resolve myself in settings but I am unable to find the settings in the router. According to this guide: [https://www.4gltemall.com/blog/tag/...com/blog/tag/huawei-5g-cpe-pro-nat-settings/)
The settings should be under: Advanced - Security. However, under those categories, the only settings that are showing are: Firewall, MAC Address Filter and Domain Filter. There are a lot of settings missing!
I have read online that sometimes carrier's can limit access to these settings but I did not purchase the router from a carrier I purchased from: [https://www.clove.co.uk/products/hu...-5g-wifi-hotspot?_pos=1&_sid=b87efbd1e&_ss=r)
Also, I have bought two sim cards from different carriers and this makes no difference either. How do I get these settings? I am looking to purchase a Synology NAS drive for file storage and to become a media server and I'm pretty sure they have to be enabled, I may be wrong.
Even if it’s not from the carrier the device still has a ‘carrier/provider’ etc installed. You can ask where you bought it from is they have a different firmware which isn’t as limited.
The security settings on mine look like this.
What software version does yours have?
Software version 10.0.1.1(H312SP1C983).
Mine is the H112-370, could yours be the H112-372 varient?
Mine is also H112-370 but it is Three branded.
What about these details?
Hardware version
WL1H112M
Software version
10.0.3.1(H330SP20C21)
Web UI version
WEBUI 10.0.3.1(W2SP20C21)
Configuration file version
H112-370-CUST 8.0.1.3(C21)
Interesting.
When you say branded, is that the hardware itself, or the UI, or both?
My details are:
Hardware version
WL1H112M Ver.A
Software version
Web UI version
WEBUI 10.0.1.1(W2SP12C7110)
H112-370-CUST 8.0.1.1(C1217)
Interesting.
My details are:
Hardware version
WL1H112M Ver.A
Software version
Web UI version
in terms of hardware branding there is no 3 logos or anything like that. It just looks like every other Huawei 5G CPE Pro the only thing is the default Wi-Fi network name:Three_002100
in terms of you UI would definitely say there are differences even the settings come up as Three broadband. I don’t get to change any of network searching options or to enable or disable 5G. I also don’t get any of the SMS settings and unable to receive SMSes.
I do have the SMS section and the UI title is just 'Mobile Broadband' for me, and I think my default WiFi network name was in the format 'Huawei_#####'.
I do not have the option to select the network modes under Network Searching either though.
I put this down to either because there aren't (yet) and SA 5G networks in the UK or that I am not actually in a 5G signal area, so it wasn't giving me the option because of that.
I think mine is unbranded - it certainly doesn't have any provider names splashed through the UI like yours. I got it 2nd hand so it could be originally supplied by Vodafone, assuming they don't actually touching within the software.
It wasn't network locked when I got it and the box/documents did not reference any provider.
I'm not sure it is something I can actually check unless the software version contain a reference to a provider - yours being C21 (for Three) and mine C1217 (for Generic/Vodafone).
Edit: looks like @Buggerlugz cross-posted on thinkbroadband with his B535 software versions - assuming that his B535 was provided by Three then that does add credence to my thought that C21 is Three's software version code.
Virgin Media £26.00
Shell Energy UK ISP Logo
Shell Energy £26.99
109Mbps
Plusnet £27.99
Zen Internet UK ISP Logo
Zen Internet £28.00 - 35.00
YouFibre UK ISP Logo
YouFibre £19.99
BeFibre UK ISP Logo
BeFibre £21.00
Gift: £25 Love2Shop Card
  1. FTTP (5507)
  2. BT (3513)
  3. Politics (2534)
  4. Openreach (2296)
  5. Business (2259)
  6. Building Digital UK (2243)
  7. FTTC (2042)
  8. Mobile Broadband (1970)
  9. Statistics (1787)
  10. 4G (1662)
  11. Virgin Media (1615)
  12. Ofcom Regulation (1458)
  13. Fibre Optic (1393)
  14. Wireless Internet (1388)
  15. FTTH (1381)
