MrDave
Top Member
Hi guys, new to this forum and it's brilliant, some great info.
I've the same issues as most on here with the B535 router on 3 mobile us. I was on a BT landline giving ~ 1Mb DL and 0.3Mb UL. The issue I keep having is that my B535 is working perfectly on the green light with 5 bars of signal giving ~ 10Mb DL and 6Mb UL then it changes to the blue light on 1 Bar of signal and the UL and DL drop through the floor. Anyone know how to resolve this or limit it from going into the better blue bars?
It's probably switching cell towers.
Try pointing the router at the nearest tower, or use the carboard & tinfoil around the back of the router hack to see if you can lock it to the best tower, if so then getting a directional antenna might help.
smithbill17
Top Member
I think you'll find the B535 manual here:
and it seems to indicate that the Green LED simply indicates that the Ethernet interface is connected. Blue = UMTS, Cyan = LTE
I don't know the answer to your question, but I'd suspect at the time it changes to Blue (Cyan?) it's switching to a different mast/cell. Perhaps you're borderline signal area and it's bumping from 3G to 4G or vice-versa. Check the System Info page before & after the change and observe if the Cell ID has changed. Or use the huaCtrl app to check.
Try changing the B535 settings so it's either 3G only or 4G only (I forget which menu its in).
Try relocating your B535 to an upstairs window closer to wherever your best Three mast signal is.
Try using huaCtrl app to make it switch to Band 1 or 3 or 20 only (depending on your area).
If all that fails. Switch to Vodafone :)
smithbill17
Top Member
Actually, I suspect you're mistaking the LED as being Green, when it's actually Blue (where Blue = UMTS ie. 3G), and Blue when it's actually Cyan (where Cyan = LTE ie. 4G).
And most likely it's working okay on 3G (ie. Blue) but along comes a 4G signal (ie. Cyan) and it thinks "I'm gonna try that!" and because it's kinda pathetically weak, the performance dies until it decides to switch back to 3G. So I suggest you try changing your B535 settings to "3G only" until such time as Three bother themselves to upgrade your local mast (don't hold your breath!)
Or you could be mistaking Cyan for Green, and Blue is Blue. In which case it's the other way around, it's switching from 4G to 3G. Either way, change the B535 settings to either 3G only or 4G only and report back :)
smithbill17
Top Member
my just stays blue, always has and has never changed?
Blue = 3G, Cyan = 4G. So you must have it set to 3G only (or you live in an area where there is no 4G).
Pinkyfloyd
Does anyone know if the B535 that comes with Three's 4g broadband is unlocked as i'm looking to sell mine on.
smithbill17
Top Member
Yes, it is unlocked (at least mine was back in January). The Three Customer Service guy who sold me their 2year contract even told me to sell it on eBay if I was going to stick with the B525 I already had. Be aware though - the Three B535 has slightly different firmware to other B535s, but I think the differences are minimal with the exception that Bridge Mode does not exist.
Pinkyfloyd
Great thanks. I will state it is unlocked but does not have bridge mode and was previously from Three.
roden
Im getting 88-92mbps down so cant see its in 3g mode, maybe its my eyes but looks blue to me.
smithbill17
Top Member
Switch it into 3G only and you'll see if it changes to a darker/deeper blue. As Buggerlugz says, Cyan (ie. 4G) is a lighter green/aqua-marine colour. A dumb design like much of what Huawei churns out.
smithbill17
Top Member
"sadly Three UK was named the worst for mobile gaming"
Looks to me that Three were close to the worst in every category!
Full report here.
Buggerlugz
Three's 5g marketting team seem to have gone dark just lately too. Wonder if they've realised they can't deliver on their promises and are feeling some stoicism?
Though the report startlingly shows that even EE winning has pitifully bad speeds nationally on 4g, just like all the carriers.
Just rebooted my router.....lets see what three's marvellous 4g is like tonight...
Why doesn't 4g deliver the speeds its designed to in the UK? Back-haul could be one reason, though I firmly believe the reason we don't see 100Mbps+ over 4g isn't because they can't deliver it, but because they don't want to.
TTJJ
Even from the beginning of 4G Three had crap speeds.
In the days of 3G they really one upped the other providers but now it just doesn’t ever get better.
If the prices weren’t as good as they are people probably wouldn’t put up with it.
smithbill17
Top Member
85Mbps here
I think you're very lucky. I've just done half-a-dozen speedtests and it ranges from 4Mbps to 14Mbps download on Three B535 5Ghz with direct line of sight to mast. As TTJJ said, if it wasn't for the price, I wouldn't put up with it.
Buggerlugz
Yes, it seems to accompany an increase in bufferfloat, so I have no idea what sort of QOS three is doing over its network, whatever it is, its not working very well.
  • Hyperoptic £20.00 (*25.00)
  • Plusnet £21.95 (*38.20)
  • Vodafone £22.00 (*25.00)
  • NOW £23.00 (*32.00)
  • TalkTalk £23.00 (*29.95)
    Gift: First Month Free
  • Hyperoptic £25.00 (*35.00)
  • Gigaclear £26.00 (*54.00)
    Speed: 400Mbps, Unlimited
  • Vodafone £26.00 (*29.00)
  1. FTTP (3398)
  2. BT (2984)
  3. Politics (1891)
  4. Building Digital UK (1889)
  5. FTTC (1872)
  6. Openreach (1796)
  7. Business (1641)
  8. Mobile Broadband (1443)
  9. Statistics (1388)
  10. FTTH (1363)
  11. 4G (1249)
  12. Fibre Optic (1150)
  13. Virgin Media (1139)
  14. Wireless Internet (1135)
  15. Ofcom Regulation (1126)
  16. Vodafone (822)
  17. EE (816)
  18. TalkTalk (750)
  19. 5G (735)
  20. Sky Broadband (731)
