I’m hoping someone might be able to help, I’ve changed the 4G antenna to face 13054 and it connects to Band 1 only, but when connected to band 3 there is no 5G like what was happing before. So I have LTE H running 24/7 band locked to just Band 1 which works a treat. The only problem, half way thru the day the 13054 masts speed cap is applied to download only and then I’m on 30-100 Mbps max. Before I would get a steady 700+ Mbps. I have 2 auto band forces setup, at 6am and 7pm. Forcing bands fixes the problem till the next day. I can’t setup a band force mid day due to working on zoom and the call dropping. Just to note while this happens nothing has changed signal wise, hasn’t dropped from the original connection and has the correct uptime. 5G signal hasn’t dropped and band 1 by itself does about 30 Mbps. Thank you in advance.
