If it is one of the ex-Three models then they disabled the API access in firmware unfortunately. You can use the Javascript injection method if you can login on the web access.Can any one shed any light on why I cant seem to log in to my CPE pro via LTE-H? username and password/ip are all correct
This is a utility for band locking etc that I use instead : https://github.com/gazzasat/huawei-cpe
I believe the Three 4G Routers were Unlocked, when they started banging out the 5G CPE they were Networked and Firmware locked, at least until the Gov Unlock thing come into play last year meaning after that date Devices sold were susposed to be Sold Unlocked, although the Firmware may still be restricted.Top work, thank you I will try this. Oddly my three supplied 535 a while back was not API locked must be something they did on the newer stuff to keep people out
The Java Script that GazzaSat suggested does what it says on tin, if it's just Band Locking your after I tend to find the Free HuaCTRL App is pretty useful and easy to use.
Yes, but a few have said the Free is not there at the moment, showing for me.Is that on android only? As I could only find the paid verson on google app store
