Huawei router power consumption
iceze
I'm trying to work out if I can run a Huawei B535 on usb. I know they're 12v but don't have a power meter or a way of measuring it.
Does anyone have the same or similar router that can measure power usage idling and load?
TTJJ
The routers power supply is rated at 12V/1A but normal USB is about 5V/1A so it’s not going to be correct.
USB can support higher power but that’s with power delivery which the router isn’t going to support if you use a barrel plug adapter.
You might get it to turn on whilst idling but once it starts using a bit more power and activity is happening you could cause some issues using incorrect power.
    Avg. Speed 50Mbps, Unlimited
  • Onestream £22.49 (*29.99)
    Avg. Speed 45Mbps, Unlimited
  • xln telecom £22.74 (*47.94)
    Avg. Speed 66Mbps, Unlimited
  • Plusnet £22.99 (*35.98)
    Avg. Speed 36Mbps, Unlimited
  • Vodafone £23.00
    Avg. Speed 35Mbps, Unlimited
  1. BT (2769)
  2. FTTP (2756)
  3. FTTC (1785)
  4. Building Digital UK (1743)
  5. Politics (1667)
  6. Openreach (1622)
  7. Business (1434)
  8. FTTH (1340)
  9. Statistics (1241)
  10. Mobile Broadband (1227)
  11. Fibre Optic (1064)
  12. 4G (1057)
  13. Wireless Internet (1021)
  14. Ofcom Regulation (1015)
  15. Virgin Media (1006)
  16. EE (697)
  17. Vodafone (669)
  18. Sky Broadband (668)
  19. TalkTalk (663)
  20. 5G (517)
