Huawei / Soyea B535-333 no 4G data on Lebara ?
cancunia
Super Pro Member
For some odd reason I can't get any data download at all on Lebara 4G with my B535-333. It only works properly on 3G. On 4G, the router is showing a good signal and an upload speed but no download speed & I can't get to any internet sites. I've tried various Voda APNs in addition the the official Lebara APN but no success.
The SIM works fine in another 4G router and also on a phone, so it's the B535-333 having the problem.
The router was originally on Three UK and works as expected on my iD mobile SIM & also on an EE SIM.
Any thoughts as what the problem is / how to resolve are welcome.
Well, today it's working! The differences from yesterday are that it's in a different room on the other side of the house, so maybe on a different mast and I have the router set to 3G only.
@cancunia - I also tried this router and had no data work with either Voxi or Lebara unless in 3G mode.
Will be running some tests this weekend using Voxi and Lebara on a new TP-Link MR500
IIRC the Lebara SIM worked fine on my older Proroute GEM 420. I'll try the Huawei again today and see what LTE HMonitor shows.
LTE H-Monitor does not seem to be working on my B535-333.
I can login, but there is no data displayed. I'm guessing that the API has changed with the latest version of Three Firmware (11.0.5.51).
I've tried various Vodafone APN's but no luck. It does work fine on 3G with the Lebara APN ..
Well, today it's working on 4G, but on a different mast than the other day. Unfortunately, the Cell ID reported by the router is not correct, or at least is not recognised by CellMapper.
I give up, after changing the settings from 4G to 3G & then back to 4G the internet is no longer accessible. Just as well I don't intend to use Lebara 4G on this router for my Broadband when my ADSL contract expires. It does work acceptably on 3G, but not so well as iD Mobile.
