In urgent need of advice - moving to remote house next week.
tommydog
Try to see if the bands change, when speeds change. You should be able to lock onto a band.
Thanks for the tip, I will keep an eye on that. This is a screenshot of the current stats
sheephouse
Top Member
I believe the CQI is only displayed if the signal quality is above a certain level (SINR > -6?)
There are step changes in the number of payload bits per frame at each CQI value - and the modulation type changes between 6-7, and 9-10.
You should see much better throughput when it is 9 than when it is 7.
From your stats it does look like you have a rather weak signal, and the Band 20 you're connected to only has a 10MHz channel width (mine is 20MHz).
Your RSSI and RSRP values look OK (but not great), but your RSRQ is low - so there may be some interference . Direction may make a difference even if you move off the direct line to the mast if it happens to reduce the background noise.
tommydog
If it is interference, why do I get decent upload rates (sometimes more than 3 times the download)? It seems all very strange to me
  • Hyperoptic £20.00 (*25.00)
  • Plusnet £21.95 (*38.20)
  • Vodafone £22.00 (*25.00)
  • NOW £23.00 (*32.00)
  • TalkTalk £23.00 (*29.95)
    Gift: First Month Free
  • Hyperoptic £25.00 (*35.00)
  • Gigaclear £26.00 (*54.00)
    Speed: 400Mbps, Unlimited
  • Vodafone £26.00 (*29.00)
  1. FTTP (3398)
  2. BT (2984)
  3. Politics (1891)
  4. Building Digital UK (1889)
  5. FTTC (1872)
  6. Openreach (1796)
  7. Business (1641)
  8. Mobile Broadband (1443)
  9. Statistics (1388)
  10. FTTH (1363)
  11. 4G (1249)
  12. Fibre Optic (1150)
  13. Virgin Media (1139)
  14. Wireless Internet (1135)
  15. Ofcom Regulation (1126)
  16. Vodafone (822)
  17. EE (816)
  18. TalkTalk (750)
  19. 5G (735)
  20. Sky Broadband (731)
