Lucian
You won't find it on Amazon, but looks like CeX has it for nice price. It's a cat22 device, "light years" ahead of the B535 or TPLink Archer.Ah, I'll stop looking at the B535 then
I can't seem to find anything higher than Cat7 when browsing Amazon. And I can't find what the spec of the Zyxel NR5103E router is that was recommended earlier *mind, blown*
Don't get the NR5103 (ie without trailing "E") as it's a dumbed down version of the device sold by EE.
Also available on Ebay from Eternal Communications (good seller, grade C is usually perfectly fine):
UNLOCKED ZYXEL NR5103E 5G WIFI 6 MESH ROUTER 4.7GBPS + 4 x ANTENNAS (UK SELLER) | eBay
UNLOCKED ZYXEL NR5103E 4.7GBPS 5G Wi-Fi 6 ROUTER (WHITE) WILL WORK WITH ANY NETWORK SIM CARD WORLDWIDE Contents: 1 x Zyxel NR5103E 5G Wi-Fi 6 Router (White) 1 x 3 Pin UK Mains Plug (If you require a 2 Pin EU/USA/AUS Mains Plug instead, please leave a message after purchase) 1 x Quick Start Guide...
www.ebay.co.uk
