Lan speed
Unoborth
Hi all Getting good connection from mast one mile away with outside antena but confused re the lan speed on lan 1 and 2 any way to change settings ?
Dodgy Cable maybe? Both ports should be Gigabit.
Could well be the cable, BT and a few others had a nasty habit of supplying cables with only half the wires present (4) which is fine for 100Mbps but not 1000Mbps which needs all 8 wires. You should be able to see the number of wires through the transparent plastic plug.
ironically l had speed issues a week back, firstly a cable one lol, had a cat 5 to my second router l realized which l upgraded to a spare l had to my second router, then my lan network on my pc decided to revert to a 100mbps link as week later for some reason, went into device manager, network adapters then looked at my settings under speed and duplex it was set to auto dropped it down to 1gbps which got me my 500mbps speed back..
it was weird my speed went to 100mbps, not sure we have the same issue but its worth checking the settings.
