Late packets and occasional packet loss on Huawei H112-370
ObviousGhost
Router is running 10.0.3.1(H330SP51C21) and is connected to the router through an ethernet cable (Cat5e or Cat6 can't remember). A reboot seems to fix the issue but only temporarily.
Any ideas? I read that disabling IPv6 can remedy the issue, though I don't have access to those settings. Is it possible to access those through HuaCtrl Pro? or maybe any other threads that have information on how to enable the hidden settings on my router?
Set it IPV4 Only by setting up a New APN Profile, save it, set to Default Profile then Reboot.
..... and no, HuaCTRL Pro will not let you change de the IPV Settings, you could try the Huawei Android App, either Huawei HiLink or the older one that I can't remember the name now, you may get lucky, other than that your down to using Windows with some Script Trickery.
Tried the Huawei app, it was called AI Life, believe it has been updated from the HiLink app. App worked fine but there were less available settings than through the router. Going to have to go the script route, Not sure where to even start with that but I'll do some research and see if I can figure it out.
Really thought the problem had resolved itself but it happened again today, reboot fixed it as it usally does though I don't want to constantly have to reboot the router.
I've probably got the Windows hack on my Lappy somewhere, but won't be able to access it for a day or two, I, ll post up or send you a PM.
Chris.
