LTE H-Monitor login
Pinkyfloyd
Hi i'm a right noob to all this and i have downloaded LTE H Monitor but i can't log in. I'm with Three Broadband and i'm obviously entering the wrong information. I know the password for my Huawei B535, I assume username is admin as i don't remember changing it. So that leaves i must be getting the router IP wrong. Can anyone shed some light on what i'm doing wrong please?
ye
Thanks but still no joy. i'm using the login IP on the homepage of my B535 router, is this correct?
Yeah, make sure the IP is correct, I think the default is different. Mine is 192.168.8.1 for example. User admin and password is admin password.
ye
My IP address changes every time i log into the Router. Previously ended in 106 and now l02.
Here is what i'm entering.....
Router IP : 192.168.8.102
Username : admin
Password : the password i use to log into the Huawei B535 Router
When i select login, it will spin for a bit and then get the message (Can't log in)
If i use your IP for example it will instantly say i can't log in but with mine it seems like it at least is thinking about it as it spins.
Username : admin
Your router IP should never change. Unless you change it?
http://192.168.8.1
What does it do if you click the link above?
Hi I have a Huawei B2338-168 router and I am trying to access it through LTE H Monitor but i can't log in Is there any software or a workaround for this?
Have you tried the fixes outlined above in the rest of the thread ?
eg Change login Method dropdown to API and try again posted by Mr Dave, it worked for my B525.
I also have this problem and have tried to connect from two different computes as well as the suggestions above, what is odd for me is that I can't even use the "find" (search) function to see the router? Does this still work?
Are there any further suggestions?
