dabigm
Hello All,
Wasn't sure if I should stick this into the mobile/voip or in the broadband section so apologies if it's in the wrong place. Long story short, I'm starting to mess around with phone calls on my modem. I got a cheap handset and plugged it into the TEL port on my Huawei 5G modem, but when I lift the receiver all I hear is BEEP BEEP BEEP (not a dial tone) and dialing any number fails.
Here's a recording of the sound. https://vocaroo.com/1l53prQkvBOW
I know some people have had it working, there doesn't appear to be any options I need to configure here. Is this a firmware thing? a network thing? How do I get this to work ?
If I call the SIM card number, it just goes straight to voicemail.
I have two Huawei 5G CPE Pro 2's and they both do this. I've tried O2 and Three SIMs both the same. Both SIMs do have the ability to make calls (they're not data-only SIMs)
Thanks.
Thanks.
