Mobile BB monitoring tools
Just signed-up with Orange Internet Everywhere, having gotten a bit fed up with O2's coverage.
I noticed on some forums that you can't monitor your bandwidth use via the accounts page. Is this correct?
If that is the case, I'm looking for a BW monitor that supports differentiation between ISP's, ie, at home I don't want to monitor my Virgin Media connection, but on the road I do want to monitor Orange.
Any ideas?
Glenn
:confused:
My mobile broadband is with T-Mobile, they supplies the USB dongle, you push it into the laptop and it starts installing its own program which has everything in it, bandwidth monitor the lot. I presumed all mobile broadband companies did that.
Or you could download a seperate program, theres a few out there, ive only ever used www.dumeter.com
After youve installed the program, go into the tools/options and select which interface for the program to monitor, select only the USB dongle whatever its name may be, so it doesnt monitor other networks such as your home cable/adsl whenever you connect those up.
