Mobile Phone Batteries
I'm about to buy a new mobile and battery life on standby is one of the main things I'm looking for. I see one manufacturer claiming 360 hours standby with a 720 mAh NiMH battery, while another claims only 150 hours for a 850 mAh Li-ion battery. Do I ignore the manufacturers' claims and choose the one with the highest-rated battery within my price range?
Maybe one phone uses (alot) more battery life on standby than the other?
I think that the manufacturers claims are usually pretty accurate (maybe slightly exaggerated).
<small>[ 20-07-2002, 09:34 PM: Message edited by: Dac ]</small>
Your best bet is to speak to the carphone warehouse, as they are indepdent and should be able to give you all the information you need.
<a href="http://www.carphonewarehouse.com" target="_blank">Carphone Warehouse</a>
ignoring the manufacturers and going for the biggest battery is about the worst thing you could do - like Dac said some use more battery on standby, such as crappy screensavers/motion crap etc....
of course expect a little less than advertised, but they all exaggerate (nokia the worst)
